Toad Left Turn signal not working.
B&T RVers
Vero Beach, FL
40"
2018 Jeep Wrangler Sahara
I tow a Jeep Wrangler behind my Ventana. I use a Blue Ox tow package with an AirForce 1 braking system.
Today while getting ready to leave we notice that the left turn signal on the toad was not working while connected to my rig. It works while not connected, so I know it is not a bulb issue.
I am guessing it is either a wiring issue, or a connector on the cable. Any ideas out there? Which colored wire is for the left turn signal?
Thanks in advance.
I would check the actual connectors and verify the wires are all tight on both ends first. They vibrate and can get loose enough to lose a connection. If needed the wiring diagram for the AirForce1 model would be able to tell you which wires do what. Should be available on their website or through support
Dont know which chassis your on, but I assume the turn signal lights work on the coach?? Freightliner has a PDM recall going and one of the symptoms is intermittent non functioning turn signals, clearance lights, etc. Just a thought after I posted previous.
