Towed vehicle battery dead upon arrival at destination
Pat O'Sullivan
This summer we installed a Blue Ox tow package with a Stayinplay braking system. I own a 2007 Newmar Canyon Star 3303 which according to all info I have, it will keep the towed vehicle's battery charged while driving. Our first trip away resulted in a dead car battery when we arrived at the RV Resort which was embarassing and required a boost. This happens when I drive more than 4 hours without checking on the car during the trip. I checked for current at the plug in and got none. I spoke with the installer who said that it might be a blown fuse. Now I have to figure out which is the right fuse. Does anyone know exactly where the correct fuse box is located and which fuse it is?
It can only keep your battery charged if you are running a 12 volt charge line and connecting to your battery via a charge controller.
Your fuse should be located under the hood of your coach. If you have a test light or multi meter, you can check to see if you have power at the trailer connection. You can google for a 7 pin wiring diagram image to show you where to check. You can also google for a 2007 Ford F53 under hood fuse diagram that will show you where to check.
Perhaps take a step back if you don't find the problem right away, and consider placing a LiFePo4 battery in the toad to power that add-on job independently.
We place a 100 amp hour LiFePo4 on the floor of the back seat of our Ram 2500 Tradesman Crew that pulls our camper to independently power a piezo cooler with our lunch in it as we go out day tripping in it away from the camper.
Not ever gonna end up in a "no start" circumstance from the cooler depleting our starting battery while we were hiking an area of interest or otherwise spend time parked during the day. Preclusion of potential collateral problems by use of independent source load separation is a superpower!
SO on they typical 7 trailer harness connection there is a power lead. I have installed a 12dc charger under the hood of our toad. No dead batteries
May be a fuse n the charge line where it is connected to the toad battery as well. We have a blue ox setup on our Cherokee and there is a fuse at the battery connection.
That is probable the best place to start checking. Work from the end of the circuit to the source.
