Towing ability
MAV1763
I have a 2026 GMC1500 AT4. Wife and I are interested in getting a NoBoundaries 21.0 overall length 29”9’ cabin length a little o er 26 feet. Max weight 8200
My question can I safely tow this trailer with a max payload of 1567 pounds Ana a max tow capacity 8900 pounds Fully loaded WITHOUT filled tanks. The weight sits at 7165
We’re new to camping trailers and are a little
Overwhelmed with a the differing info on internet searches
Thanks
What's the quoted hitch weight on the NoBo? Payload is probably going to be your limiting factor.
Hitch weight is listed as 740. That’s a little over 1/2 my payload I know 🥺😳
For a 1500, I would probably look for a trailer that's 1000-1500 lbs lighter, though your length on that one isn't too bad.
Thanks. I was planning on upgrading the front brakes to help with stopping. Shoukd
Have gone with the 2500 like I was considering 🤦🏼‍♂️
Thanks
Multiply what's doing the towing by .80 ie., if your max towing is 8,900 lbs. you probably shouldn't be extended towing over 7,120 lbs.
You might want to check the max tow spec. That sound real low. My last F150 had a 12k mqx tow. I still upgraded to a 250.
It's probably legit. The AT4 is an off road trim with soft suspension.
For reference, what's the towing capacity of a Raptor?
We tow our aluminum frame and sidewall 6500 lb Intech OVR Navigate using a 2024 Ram Tradesman 2500 Diesel Crew, with alumimum service body added, those doors stuffed with camping grar and some service tools.
There is much to be appreciated in how that big puller reacts to having the aluminum 27 foot trailer attached. Go big puller and lighter trailer if you can, because one man's "too big" truck is another man's un-stressed capability reserve..
