The the trailer is going to be 7500lbs according to specs.. probably more in the real world.. doesn't sound like a fun pull at all.Looking at a 2014 Forest River Coachman 281 RLDS. I want to see if my 2005 4WD Silverado 5.3 Z71 Extended cab short bed can pull this TT safely.
AThe the trailer is going to be 7500lbs according to specs.. probably more in the real world.. doesn't sound like a fun pull at all.
Why 80%? The rated capacity is the rated capacity. If it was not safe to tow up to the rated capacity, then it would not be rated for that capacity, it would be rated lower. I guarantee for liability reasons there is already a "fudge factor" built into the rated capacity number.Most suggest that you only use about 80% of the truck's capacity for safety also.
Because that gives you some extra margin for safety especially in an emergency situation.Why 80%? The rated capacity is the rated capacity. If it was not safe to tow up to the rated capacity, then it would not be rated for that capacity, it would be rated lower. I guarantee for liability reasons there is already a "fudge factor" built into the rated capacity number.
Well, I suppose that driving 80% of the speed limit probably would too. But I suppose just because some people recommend not going above 80% of capacity is not a requirement, just a recommendation.Because that gives you some extra margin for safety especially in an emergency situation.
Well, I'm in for an adjustment. I sold a single axle 20' trailer and I'm getting a 26' dual axle. Also, I notice there is a lot more trailer behind the wheels on the new trailer compared to the old trailer. So, I'm expecting some fun backing-in experiences the first few times. And with the Dodge Durango I bought just to pull the new trailer with, I will be under 80% weight capacities anyway. I was maxed out on weight pulling the old trailer with a Grand Caravan mini van.EXACTLY.....Some people need as much "help" as they can get. They seem to think towing is just like driving their car to go get a latte..........
