- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I chose the TST Truck TPMS before I took delivery of my 2017 Newmar Ventana. At that time it was the black LCD display which I really liked. I bought the repeater and mounted in the half bath for easy access to the 12V fuse panel to tap into for power. Works great with the toad in that location. Later I bought the color display. Initially had some frustration as the tire pressure and temp locations were reversed from the black and white model. I've seen become used to it and really enjoy the color display. I do not keep the unit in view while driving as mounting it was a challenge so I used a velcro option from a bracket I 3D printed so I can slide it out and view as needed. I check the pressures prior to departure and then if there is a problem I will hear the alarm based on the config per TST's recommended settings. I have had the alarm go off and it's no problem hearing it, it's loud and annoying. I've been satisfied on the accuracy of the tire pressures when comparing to my gauge used when filling the tires. I have the flow thru sensors, TST came out with the brass quill versions which work outstanding. I've had no issues on valve extensions either. Highly recommend the TST TPMS system.
tsttruck.com
My 3D printed bracket for the color monitor:
www.thingiverse.com
I've met Mike, the owner, at rallies and he has been super helpful with any questions, warranty replacements, etc. Great customer service.
I am NOT affiliated with TST Truck.
All Products
Truck System Technologies (TST) Color Display Mount Bracket by NealC
My class A motorhome has a tire pressure monitor system by Truck System Technologies (TST) and I use their color display. The display does not have a reliable mounting system although it comes with a rubber stand and a suction cup mount which don't work in my RV well. I designed a simple mount...
