TV on televator
Highroller
Hello the tv on the televator that rises from behind the fireplace I need to replace. I've been studying it but have yet to figure out how the tv comes off the televator, can anyone help ,me out with how to remove the tv
No coach identified.. So in my Ventana the tv is mounted to the elevator by four screws thru the brackets into the tv. Not the easiest to remove but can be done while in the up position.
As I recall, some have removed the window screens to gain access from outside.
@Highroller , add your rig information in the sidebar, which can help give more accurate information.
See if this helps you, I replaced mine, no need to go in from the outside.
I replaced mine from removing screws from the inside. I built up the corners to the tv so there was no drop when i got the screws removed. Not in easy positions to remove.
