Thank You very much i will get one on order.Welcome.
Lightning to HDMI Adapter with Lightning Digital AV Adapter 1080P, Lightning Charging Port White for Select iPhone iPad and iPod Models and HDTV Monitor Projector (Withe) https://www.amazon.com/dp/B09P3L6M4V/?tag=rvf01-20
You will need a good WiFi signal, hdmi port on the TV and the above adapter and you will be able to stream. If you use Direct TV at home you can stream from your tablet. We do it all the time m.
However, i just red the description and it says it is not compatible with netflix, hulu and some others. did i misread the description?Thank You very much i will get one on order.
I have used to stream Netflix, Amazon and DTV, never has a problem. As long as you have internet. I have used my phone as a hotspot if needed. Most of the time I stream from the iPad instead of a phone.However, i just red the description and it says it is not compatible with netflix, hulu and some others. did i misread the description?
ok great, we use the ipad as well. We have unlimited data on that device.I have used to stream Netflix, Amazon and DTV, never has a problem. As long as you have internet. I have used my phone as a hotspot if needed. Most of the time I stream from the iPad instead of a phone.
