yes when driving the solar will still charge your batteries. solar will still charge your batteries when plugged into shore power or generator. and if you have a inverter/charger it will also charge your batteries when plugged into shore power or generator running if your inverter/charger is turned on.When on the road with engine running, does the solar system typically still charge the battery? Does Solar help with load when you are plugged into Shore Power, etc?
