Water Deionizer Systems
ChubsBus
Anyone have a good recommendation for a Water Deionizer System for Class A use? Have a good pressure washer system, but tired of driving to the car wash or hand drying. Maybe even something portable that I could take along, if anyone has had good luck with portable units.
If you want an easy swap in and out resin tanks.
I have had the portable Di that @J&JD links above and those work great too. Those are better if you want plumb it in the bays than the simple chucks.
The 2 most popular solutions out there are bulk tanks like DI RINSE (also branded as ADAMS, or ON-THE-GO) and filter-packs such CR SPOTLESS.
DI RINSE
(https://amzn.to/3CpU8ZN) uses bulk resin beads that must be flushed out and replaced to recharge.
These last much longer between recharging and, hence, the cost is much lower. The process is more of a hassle.
The CR Spotless (https://amzn.to/3IrmOp9) uses replacable resin filters which can be quickly swapped out.
These don't last nearly as long, sometimes even a single wash if you're in a very hard-water environment such as AZ. Therefore, you'll need to carry spares and, thus, the cost is significantly higher.
I've made videos on the OTG system and recharging process, if you care to check it out on my youtube channel, "RV Squared":
For Class A use, a recommended Water Deionizer System is the CR Spotless DI-120 Deionized Water System. It is designed specifically for automotive applications and provides spot-free rinsing, making it ideal for use with pressure washers. The CR Spotless DI-120 is a portable unit that can be easily transported and used on-the-go, making it convenient for those who want to take it along for mobile detailing or other automotive cleaning tasks. It features a built-in TDS meter to monitor water quality and regeneration capabilities to extend the lifespan of the resin. Additionally, the CR Spotless DI-120 is compact, easy to use, and comes with all the necessary components for quick installation.
