Water dripping under large slide
Mctravel
American Coach
Revolution
Freightliner
2017 American revolution coach, water is dripping from under the large slide below the area of the residential refrigerator. There is a metal raceway with a drain line in it attached to bottom of the slide. The water is dripping (slow drip, drop every 20 seconds) around the area where the drain line goes through the slide floor at the outer edge of the slide.
I shut off the water to the refrigerator and checked for leaks under the sink and behind the washer dryer. No visible leaks. No water has been run down the sink drain for 24 hours.
Anyone have a thought on where the water might be coming from?
You may have to pull the fridge out and look if there is a leak from the ice maker / water line to the fridge.
Ice maker? Water valve replace
