water leaking from shower
LLevy228
I have a 2010 keystone outback 260 FL arctic barrier edition, and for the most part it's great. However, recently the shower will leak, all over the bathroom floor and under the sink, on at least one occasion it got so bad that it went under the wall and all over the bedroom carpet and I have looked and can not find the source of the leak, I don't know if it's from the water coming to the shower, like a loose connection or something. I was wondering if anyone else has this problem and any advice would be greatly appreciated....thanks
If it only leaks when the shower is used it is in the shower head, the drain line or in the shower enclosure itself.
Our Keystone COUGAR 22MLS shower also leaked water every time is was used. Placed a towel on the floor to catch the water during first season. The issue was the lack of proper sealant around the metal frame where it meets the fiberglass surround base. Water was seeping out onto the floor with the sliding door closed.
I used clear Sashco Lexel sealant instead of 100 percent silicone since Lexel sealant allows you to reapply more sealant over it if need be. I also applied Lexel at the top of the surround and anywhere else that looked like a gap without sealant. Silicone won't stick to itself so no applying more silicone over dried sealant, you have to remove it all and do it again. Hope you figure out where your water is coming from and get it fixed.
