Douggarvin
- Apr 5, 2022
First check would be to put trans into neutral and try to start. If that's not the problem double check battery. You can have voltage but no amperage with a bad battery. These are the simplest things to check and go from there.It dead when the key is turned nothing. Battery is good. There is nothing. Instrument panel lites up, lights work. What electrical checks ( be specific). Don't have a wiring schematic
