Old-RV'er
RVF Expert
- Feb 23, 2020
- Blairsville, GA
- Ventana 3407
- 34'10"
- 2013 Jeep Wrangler Sahara Unlimited
Clearly indicated on the CAP of the coolant tank is the word COOLANT. Take the cap (cannot remember color of cap) off - twist - not threaded, and fill that tank to within 1" or so of full. This is the overflow tank. Regardless, you should check the level, at least once month, (manual says daily but if not used and not leaking!!!) and if you run genset the required 2 hours as prescribed then after it has cooled down, like the next day works. The coolant should be blue I think, but the same that goes in the engine (diesel assumed) will work, if gas powered, and genset is not, then consult owners manual for correct type. I have attached the operators manual for the 7.5-8.0 KW diesel powered units. Take note of the coolant section. And please also note, the radiator cap should be replaced every three years, when you drain out the old coolant and replace with new. I believe the main engine also needs this done, cannot remember the interval.
