Question Wheel alignment report
Buly
RVF 1K Club
TGO Titusville FL
InTech
In-Tech Dusk travel trailer
Aluminum
Lexus GX460
Last week I took our DS to JOSAM Orlando for wheel alignment. They told me the report is included, but it was not an explanation in plain English. Just a graphic representation with bunch a numbers and angles. I just wanted to know the before and after condition of the wheel alignment.
Wander if anyone here knows how to read the report and let me know?
Thanks
I would tell you but then I’d have to kill you.
Comparing the numbers from one side to the other it appears that you needed the alignment. There was quite a bit of difference in some areas. Your tires will thank you.
Thank you EZ. I was getting wear on the front passenger one. The outside was wearing faster. I thought since most of the time we were in the right lane, correcting all the time for the crown on the pavement was doing it?
Glad I did it..
I've had motorcycle tires that wore unevenly due to the crown in roads (wear on one side but not the other) but I've never seen a car or RV tire do it. But your numbers were quite a bit different from side to side so one side or the other were off. I'm not sure what the numbers are supposed to be on an RV but they should be the same from side to side.
