Never mentioned using spacer, but I agree. Just thinking if dually has wider track and better stability, by moving tire/wheel about 1” or so further out (using min. Factory wheel/tire weight specs, could I get a little better tow stability with srw?Need more info on the toad...I have moved offsets on several vehicles for differing purposes.
Never use a spacer. They are dangerous. Even properly installed, it requires frequent maintenance and torqueing.
short answer no.Never mentioned using spacer, but I agree. Just thinking if dually has wider track and better stability, by moving tire/wheel about 1” or so further out (using min. Factory wheel/tire weight specs, could I get a little better tow stability with srw?
