Where do these rubber tabs found on steps go?
JRS
RVF Expert
Full timers
Dutch Star 4328 - FL Chassis
2018 Jeep Grand Cherokee
Another was found this week on the stairs and now have a total of 4. They are found on the stairs/steps and similar in size to a nickel. How are they reattached? Thanks in advance for a response/s.
Are they part of the screen door? Not sure what those are!
No not the screen door. I think goes somewhere for the step cover
My RV has those two of those holding down the step cover over the battery.
I found where these go. Quote from another forum and these should end up facing up so that the cover rests on it when retracted.
"They are the rubber feet that attach to the bottom of the step cover slide out to keep it from rattling while driving. Stand on the ground outside the coach with the door open and extend the step cover. Look underneath, and you will see the little holes on the bottom rail they pull up through. Wet the rubber tips and the using some needle nose pliers or small hands you pull the small tip up through the hole until the pad seats up against the rail. The expanded rubber part is to keep them in the hole. Doesn’t always stay though".
