Where does it go.
Russellvh
Forest River
Wildcat Fifth-wheel
2019 Ford F-250.
Yes
2022 Wildcat 5th wheel #333 RLBS. My underbelly is sealed so I really can’t “just look”.
Curious if my bathroom sink drains to the same drain tank as the kitchen sink or bathroom shower.
I assume you have 2 gray tanks, empty your tanks, run water from the bathroom sink, open the tank valve and see which one has water, repeat with each area
Or put a little food coloring in the sink and see, assuming you have two tanks.
I like the food coloring idea, good thinking. The floor plan may be helpful, if your two sinks are a long distance apart, I would expect they drain into different gray-water tanks.
RE: Food coloring
My elderly in laws were getting outrageous water bills so they contacted the water dept. Ultimately, they were told to put food coloring in the toilet tank and check the bowl. Sure enough there was a slight constant dribble they could not notice.
