- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
So I was thinking this morning...why are Dometic air conditioners equipped with Micro-Air Soft Starts outlasting stock Dometic units for RV's? Then I remembered long ago when my residential A/C unit had a capacitor failure which seems to be the most common cause of failure in air conditioner units, from what I recall. So is this a simple situation of the capacitor in the Micro-Air unit is more reliable and longer lasting than what Dometic is using?
Secondly, I wonder how many replaced a Dometic roof top A/C unit on their RV which really just needed a capacitor replacement? If the unit did not have a Micro-Air soft start in it, would installing one into the failed unit resolved the failure? Or are the failures some other known component? My hunch is people are discarding perfectly good Dometic units that could be fixed with a capacitor change (and upgrade to Micro-Air)?
Thoughts???
Thoughts???
