Windshield Wiper Replacement Recommendations
Here’s rhe 36” version:
Trico 67-361 36" Heavy Duty Wiper Blades Fit Select Coach Bus RV w/Wide Saddle Attachment​
$67 at Amazon
This is from my orders at Amazon for my 2016 Ventana. Most likely the same windshield and wiper assembly
Thanks!
I'm not sure how common it is, but I've read of many doing so. There are several reasons to make the switch:
1) Cost of wiper blades
2) Reduce likelihood of blades hitting each other
3) Reduce overall friction to improve wiper motor performance
4) Others?
Appreciate the help.
I just ordered a pair from windshieldwipers.com.
We’ll see how it goes.
I switched from the 36” to 32” a couple of years ago. Really can’t tell the difference in coverage. While you’re at it, check the mounting nuts for tightness. They tend to loosen up over time. I believe they should be @ about 65’lbs.
Check with Newmar for the torque for your vehicle. While many of the higher end coaches do have a torque of 65 foot pounds, the Ventana may be different.
what kind of spacers did you put on the 32" to fit tight?? may have to print something on the 3D printer to make them fit properly as the 32" are alot narrower than the 36"..
Wish I could give you a good answer on spacers. The wipers fit reasonably well out of the box and seem to work fine. These are the blade I purchased:
Thanks Jerry,
those maybe wider than the other ones.. will send the others back and give these a shot!!
Okay...I saw a lot of recommendations for the Trico. I would stick with WT (Wiper Technologies?). I'm pretty sure my second d set of blades was Trico. The Florida Sun on the wiper blade causes rubber to shrink. This allowed the tips of the blade to rub against the glass. Unlike WT...the Trico was metal instead of plastic. It scratched an arc in my glass. If you have gone Trico, or plan to. Please check the ends...metal? If so...keep tabs on the actually blade for shrinkage with aging...and replace before you etch your windshield.
great point!! you have a link to the model you ordered?
