Question Winterizing:
Arvie
Jayco
JayFlight SLX 8 212QBW
21 ft
we want to protect our 2022 Jayco in winter months but also may do some traveling to warmer climates for a couple of weeks at a time. What are the best ways to winterize but not for a whole winter? It will get cold where the RV lives in the winter. Always take battery out? Use something in all holding tano’s? Thanks everyone!
All you would need is the pink antifreeze,or you could use some heat tape to wrap the pipes, it wouldn’t interfere with the water but it would keep them from freezing
The pink stuff is the best bet, make sure to get it into every appliance except the water heater. Water heater should be isolated and drained. Not a hard thing to do each time, especially if you have the hose attached to the pump like my Jayco. Flip a valve and pump away. Run enough into the sinks to protect the p traps.
Dont forget the toilet, it has a vacuum breaker and needs to have some flow thru it.
