- Jan 19, 2021
- Ventana 3427
- Freightliner XCR
- 6.7 ISB 360/800
- 2001 Jeep Wrangler
On that “other“ forum (with the zealot mods) this would have gotten me a warning or worse, and yes Im banned for life over there, and yes I know why, but to me it makes sense to post it here as well as in the specific chassis forum. So here goes:
... I’m reading 0% soot load (OTR diagnostics) in my DPF which I know isnt right, and also cant do a proper forced regen, probably becuase since its reading 0%, the ECM sees no reason to activate the “7th injector”. So my forced regens are running around 670* instead of 100-1200 degrees. And while initially I toyed with the idea that having that sensor non-functional will also prevent any DPF related derates, it will also lead to an early death of my DPF. So, whats the problem? I cant find the differential pressure sensor. I can find them on line, and they are only around $100, but I cant locate it on my DPF. Its a 2015 XCR chassis (2016 Ventana) and it should be quite standard and fairly obvious. Can anyone direct me to the thing so I can replace it? The temp sensors are readily obvious.
