Question Fresh water tank drain valve
Pacnwlady
Kent, Wa
Coachmen
Cross Trail XL 20CB
23’ 6 inches
I have purchased a 2023 Coachmen Cross trail XL 20CB and have not been able to find where the fresh water tank drain valve is. Dealership was not helpful and information on line is not specific enough. Very frustrated. Does anyone know where it is for my model?
Welcome to RVForums! Are you talking about the sewer connection or the tank drain?
For the fresh tank drain, I can only refer to my coach but it's behind the wet bay panel, on the floor, accessible but hard to see or know what it does. It's likely near your fresh tank and you should be able to find the drains from under your coach and trace up from there.
Do not know where or what a wet bay panel is. A knowledgeable friend looked under the RV and was not able to find them. We found the low point drain. Maybe this is also the fresh water tank drain valve too?.
Sorry for the confusion, I don't know your RV which is why I moved your post to the Coachmen owners area. If you can attach pictures that can help members here better assist you.
On our Concord, the fresh tank drain is located with the low point drains. Different rig but ours is accessible inside access panel under the refrigerator.
