MemoriesByTheMile
RVF Expert
- Mar 8, 2021
- Renegade
- 45’
- ATC Trailer
- Yes
Hello.That thermostat pic is in cool mode - I assume you have flipped it to elec heat for your current use?
Wow I did not know that. Im pretty unknowlegable about that. It heated Rv last year. It seems to be working again since I switched a switch under a panel on the outside of RV. Id like to learn more about the heat strip. Now I need to figure out what is wrong with LP partThat is not an electric furnace. That is a heat strip most likely in the AC unit. The furnace is gas onl
