- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
No, I know the shop foreman at Freightliner Gaffney.You know the shop foreman at Ocala Freightliner?
A voice of reason breaks through! What's up with that????Is the ITR or Solar pump better for pumping Kentucky Bourbon?
just trying to keep the thread on track….
Thats it!! The ITR pump is a food-grade pump.Is the ITR or Solar pump better for pumping Kentucky Bourbon?
After speaking with Randy at ITR, he confirmed that this is the case.I’m pretty sure that turning on the bypass switch does just that, it bypasses the pump control and turns them all on at the same time. That is why, if you have no or intermittent hot water or heat in one zone, everything seems to work. You could have 2 of the 3 pumps be bad and the system would work with just one pump, just not as efficiently.
