- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I've been lucky as to date in nearly 7 years only one pump has gone - zone 2, about a year ago. The summer loop has been a bit loud for some time but as long as it worked I left it alone. RIP summer loop pump, you served me well, today you were replaced.
Note: Staring at the computer dreading the manual labor apparently does not make the pump change itself...so I finally went out and did the deed.
It took longer to empty the basement and reload it than actually changing the pump, I think, or about the same time.
Summer loop pump is the far left pump.
Steps:
Steps:
- Remove wall on passenger side behind OASIS area which is where the pumps are located.
- Disconnect electrical pigtail from distribution box (per ITR's instructions, RTM y'all!)
- Remove panel from pump unit
- Clamp inlet side of pump
- Stuff rags or paper towels below, stuff is going to come out, you probably should wear gloves too
- Disconnect two spade connectors
- Use pliers to squeeze the hose clamp and work like crazy to wiggle jiggle and ziggle the pump out, it's not easy, both ends.
