Rosy
- Jul 29, 2022
- Alberta, Canada
- Coachmen
- Freedom Express 25SE
- 28 ft total; 25 ft box
- 2020 Toyota Tundra
We're obsessive about glove-wearing and buy disposables by the case from Amazon. Bob has even considered a disposable suitPleading no contest...
Not wearing gloves while dumping? Big mistake!
In this day of fastidiousness and the injection of antibacterial chemicals in nearly every product, there's a strange movement out there: Dumping holding tankswww.rvtravel.com
Now you can add full ppg to your list of must haves!!!I would like to thank the participants in this thread to allow me to do something new, put yuck down my sock and shoe while finagling with the sanicon hose getting it connected at my new CG.
I don't think the way it's connected will allow me to do that. And I don't think it's from the black tank. I think the gasket on the grey tank valve is the culprit. It only started doing this a few months ago. I have since had the grey valve apart to replace the damaged pipe (stupid design) and noticed the gasket looked "aged" and dry. If it's not actually cracked to the point of leaking, then it's very close and the gasket isn't sealing completely. The first time after fixing the grey pipe, I had put several gallons of clean water into the grey system and let it sit for several days to make sure there were no leaks in the repairs. The cap had a half cup of water in it even with the grey valve securely closed. I need to buy a replacement and take it apart yet again and if I'm doing one, I might as well do both. I did have enough sense to replace the old rusted nuts and bolts on the grey valve with new SS ones. So it should be an easy fix. I just need to buy new SS screws for the black valve, dump and flush the tanks before taking the valves apart. Until then, It's going to sit with a teaspoon to a tablespoon of liquid between the valves and the cap. The more I use it the less it leaks.I used to have this problem and thought I’d have to replace the black tank valve, but I started backwashing the black valve surfaces by leaving the black valve open for a few seconds after opening the grey valve.
So just out of curiosity!!! Do you put your rubber gloves on before you wipe your.....but please don't tell me!!!There’s a bunch of people here whose hand I will never shake. Just sayin’.
one Should! but... no
Thanks for the info. I fill my bottle with just enough bleach solution to last a week or so but it is a bit of a pain in the butt. I'm sold on your solution (pun intended)! ThanksMost people think bleach (sodium hypochlorite) is a great disinfectant and it is. Many use it all the time around the wet bay and sewer system. The problem is that its potency degrades fairly rapidly when you dilute it in , say, a spray bottle so you never know if the solution is able to sanitize well. For that reason I would recommend using a quaternary ammonium compound ( referred to as a quat). These quats are extremely stable and will remain active months after dilution. You can dilute them down to as little as 1/2-1/4oz per gallon for use as a sanitizer so they are amazingly cheap to use. And many of them are food grade. And you can safely spray it on your hands! If you check the label on Clorox Wipes you will see that the active ingredients are quats not bleach. This is because quats are so stable and they will not “bleach” fabrics.
Here is an example of one used nation wide for food plant sanitation and one I highly recommend:
Amazon product ASIN B08YFHJ2C5
I see splatter in that solution as well... just saidBidet.... just sayin'
Joe I am with you. Wipes in the bay and a box of gloves. You never know what the person behind you did with the dump site especially the blaster/rinse hoses. I guess it is do what you want. I do not agree with the no glove policy. What happens if you have a cut on your finger and pick up bacteria or contaminant from the site? I equate it to having surgery and telling the Drs./ staff not to bother with gloves or sterilization.I am one of those people that has a container of wipes in the wet bay, use multiple gloves, and still wash hands when I get back into coach. Just feel better that way.
been using one for 12+ years, never had a splash back issue. much better and more hygienic solution to cleaning your backside than wiping, I mean do you use dry paper to clean your hands.I see splatter in that solution as well... just said
Now that is how to draw a crowd of spectators at your favorite campground.
