Rosy
- Jul 29, 2022
- Alberta, Canada
- Coachmen
- Freedom Express 25SE
- 28 ft total
- 2020 Toyota Tundra
We're obsessive about glove-wearing and buy disposables by the case from Amazon. Bob has even considered a disposable suit he hates the job, but has it down to a science. I'm gonna make a separate post - this funny! and hopefully will help others avoid this.Pleading no contest...
Not wearing gloves while dumping? Big mistake!
In this day of fastidiousness and the injection of antibacterial chemicals in nearly every product, there's a strange movement out there: Dumping holding tankswww.rvtravel.com
Now you can add full ppg to your list of must haves!!!I would like to thank the participants in this thread to allow me to do something new, put yuck down my sock and shoe while finagling with the sanicon hose getting it connected at my new CG.
I don't think the way it's connected will allow me to do that. And I don't think it's from the black tank. I think the gasket on the grey tank valve is the culprit. It only started doing this a few months ago. I have since had the grey valve apart to replace the damaged pipe (stupid design) and noticed the gasket looked "aged" and dry. If it's not actually cracked to the point of leaking, then it's very close and the gasket isn't sealing completely. The first time after fixing the grey pipe, I had put several gallons of clean water into the grey system and let it sit for several days to make sure there were no leaks in the repairs. The cap had a half cup of water in it even with the grey valve securely closed. I need to buy a replacement and take it apart yet again and if I'm doing one, I might as well do both. I did have enough sense to replace the old rusted nuts and bolts on the grey valve with new SS ones. So it should be an easy fix. I just need to buy new SS screws for the black valve, dump and flush the tanks before taking the valves apart. Until then, It's going to sit with a teaspoon to a tablespoon of liquid between the valves and the cap. The more I use it the less it leaks.I used to have this problem and thought I’d have to replace the black tank valve, but I started backwashing the black valve surfaces by leaving the black valve open for a few seconds after opening the grey valve.
So just out of curiosity!!! Do you put your rubber gloves on before you wipe your.....but please don't tell me!!!There’s a bunch of people here whose hand I will never shake. Just sayin’.
one Should! but... noSo just out of curiosity!!! Do you put your rubber gloves on before you wipe your.....but please don't tell me!!!
