DavidL
- May 8, 2021
- Metamora, MI
- MountainAire
- Spartan K2
- Cummins 500hp
- 2023 Corvette
While getting my coach ready for our annual trip in October, I ran the motor to air up the new airbags. The dash heat was hot, but it was set that way. I turned it to AC Max and it never got cold. So, looking at the AC compressor, the suction line was disconnected from the compressor (what?). So, I cleaned and put the fitting back on and evacuated the system for hours to get rid of any moisture from the system being open for what seems months (the fitting was seized a bit so it hadn't been turned for a while.
I fed in three 12 oz cans of R-134 and the compressor clutch engaged. A few minutes later and the low side gauge went into vacuum. So that's not a good thing. Indicates a clog on the lower pressure side so the compressor wasn't getting freon back to pressurize. So, it became obvious that crap got into the open system and it was time for a good spring cleaning. Ordered: Dryer (should always be replace when a system is opened to atmosphere), Expansion valve (the first thing that typically gets clogged as it's ports are very small), a compressor / clutch (just because they are relatively inexpensive and a high area of failure.
Parts came in and my buddy came over to lend a hand. Evacuated all freon. Opened up all fittings to all components. Removed the dryer, the expansion valve. Pushed AC flush solvent from a flush canister that is fed compressed air into all of the lines. White rag on the output side to trap any dirt. So, orange stuff came out (likely oil) but little dirt (that's a good thing. However inspection of the Expansion Valve shows the root problem. Dirt clogging the inlet...(see pic).
Dried out the hoses with dried compressed air. Attempted to install the new expansion valve and ...wrong part...so ordered the correct one now that I had the part number off (38901) the old one that was now in hand. Part arriving Friday. I will leave the system opened up to let the flush solvent evaporate and put it all back together Friday. To be continued...
