Help, house batteries not charging.
Ellano
Rookie RV'er lost and lone on my first trial run with my bounder.
I have a 2006 Fleetwood Bounder 35 E. When the generator is running all of my appliances work fine, AC, fridge , micro. Same when the engine is running. But when I'm connected to 50 am shore power everything start to dim and upon checking my AUX readout, it's dropping rapidly from 13.5. Eventually they die. The dealer I bought it from said the aux batteries are new and no one walked me thru RV lifing so this is all alien to me.
Do you have an inverter in your RV? Is it ON? Any circuit breakers popped needing reset? Is the pedestal good, I use the item below to test the pedestal so I know it's good when I plugin every time:
Amazon product ASIN B015Y9A4HU
I believe I do. The dealer really sucked and shared very little walk thru so I'm hunting. I'm sure I have an inverter , just not sure where to look for it.
No popped breakers and the led is good. Had prop manager come out to double check PED for me. 50 30 and 20 all good
I'm sorry for that. These machines are complex and hopefully the gang here can help you out and continue learning as it takes time. Include any pictures of your setup, control panel, inverter, whatever to help us better understand your rig's setup as needed.
First off Welcome to RVforums from Ely, Iowa. As Neal mentioned these systems are complex and vary from rig to rig however they have some common components/ A full power system will have batteries, Converter/Inverter/ Charger and a transfer switch. if you are having issue when hooked up to the PED have you checked your power cord? Also have you verified that you batteries are in fact new? Kind of sounds like no power getting to the rig. Also find the transfer switch it may not be switching as needed
Sounds like transfer switch is not switching over to shore power
Update. Dealer said the batteries were not replaced and so they are not charging or holding charge. Sent me home with2 new 24D 12 volt batteries to install. Asked me to check the "Converter fuses" found in my breaker box behind the breaker plate. I'll update you guys ASAP.
Also thanks for the support and replies.
A converter takes 120V and converts it to 12V - could have charger built in. An inverter is connected to the battery bank and takes 12V from battery bank and supplies 120V out - could have charger built in.
You said that everything works when the engine is running - that indicates to me that there is an inverter in the mix. Most inverters will not run the AC or other high draw appliances though. There usually is two electrical banks in an RV when it comes to the Inverter output - circuits it will power, like certain outlets, and circuits it won't power - real heavy draw circuits, like electric cook top, AC, water heater, etc. The inverter will only invert as long as there is charged batteries. The engine is probably providing a charge to the batteries. The real test is like when you're boon-docking - no power pole to plug into, no generator all the time, only charged batteries. In this situation can you turn low current AC things on? That shows how an inverter works.
No this is a separate device that switches over the power depending where the power is coming from. For example if plugged into shore power of from the generator it will switch to that power source. They are typically automatic.
Ok, yes. When it's just batteries , all low voltage items work but drain the battery quickly. Like if I have 2 lamps on and battery voltage is at 12.5 v, after 30 minutes the aux batt voltage is down to 11 and steadily dropping.
Ok, I checked all fuses. None were burned out, I installed the 2 new batteries from dealer. Started off at 12.6. I have 2 exhaust fans and 2 lamps on and she's dropped 12.4 and slowly dripping. I'm still on shore power.
Check to see what the voltage is going into and coming out of the inverter. Check the same in and out of the transfer switch. If the voltage is low or no-existent at any of these points, it will help to narrow down the source of the problem.
Also, did you check the voltage at the pole?
This may be good to have, if you are not using an EMS, like, Progressive industries, of Hughes watchdog.
Journeyman-Pro 30/50 Amp RV - Portable Circuit Tester Analyzer Adapter, Male Plug w/LED Test Indicator TT-30 NEMA 14-50 (TT-30 (30 AMP), Circuit Tester (Male Only))
Start at the pole and work your way in.
