FL-JOE
- Nov 15, 2019
- Frostproof, Florida
- Forest River
- Salem FSX 270RTK-X
- 2022 Ford Expedition Timberline
- Yes
I doubt you understand what a TPMS (tire pressure monitoring system) is. You are confusing it with the OEM system that most of our non-RV vehicles have on them where you will get that lame tire symbol on the dash when one of your tires are low.The federal government mandated tire pressure sensors with new vehicles produced after 2005 and it was to reduce excess fuel consumption from underinflated tires and for no other reason. ABS, seat belts, safety glass, and engine governors were designed to make vehicles safer but not tire pressure monitoring systems.
My vehicles tire pressures increase with ambient temperaturs and with exposure to sunlight and from the flexing of the tires while driving and so it really does not matter at all if the tire is at 65P PSI or 75 PSI. If there is a severe leak it is obvious and all I need is a $15 tire pressure gauge to determine how fast the leak is draining air out of a tire. Regardless, the course of action is to go to a tire shop and have them remove the tire and fix the problem.
I have tire pressure monitoring that was installed by the factory on our three vehicles and it contributes nothing to driving safety. I don't have one on our Class C motorhome and never will have one as it provides no benefits to safety or fuel economy over what I get with my $15 tire pressure gauge.
For years commercial truck-tractor-trailers have been using TPMS's with external sensors so that they know when they blow a tire or one of their tires simply goes flat. Obviously it is a great piece of safety equipment to have on larger RVs for that exact same reason. If one of my 6 tires on my fiver start rapidly dropping pressure while I am going through Nashville at 70mph I would prefer to know it right away with an alarm going off on my TPMS. Without the system I would simply notice pieces of my blown tires tearing up the side of my fiver and possibly hitting other vehicles.
Calsun, if you are actually doing any serious traveling in an RV, or if you even own an RV, you should consider getting a TPMS because it is actually the #1 piece of safety equipment IMHO.
