Question Auto fill?
TJ&LadyDi
RVF "Dinosaur"
Washington State
Haven't yet used this feature yet, but thought I would try it when I fill the fresh water tank after cleaning it; probably tomorrow.
Looks like I just position the valve in the Auto Fill position and enable it with the panel switch in the wet bay. Anything else I need to know?
And, how full does it allow the tank to fill. I've seen references to everything from 75% to 100%. I assume it stops before water starts coming out the duckbill.
I believe there is a setting on your Silverleaf panel to set the desired %.
I did not find a fill percentage setting in SilverLeaf, though I didn't go into the advanced settings area (couldn't remember the password but have it written down somewhere).
The Auto Fill shut off at 100% (but before any water came out of the overflow.
When I get a chance, I will look in the SilverLeaf advanced settings to see if the fill level % can be changed. I would prefer it to stop around 70-75%.
Thanks @BuckyII, I figured it would probably be in the Advances System Configuration section. I will go in tomorrow and make the desired changes.
At least, I now know how to use the system and that is does work. One more thing learned...and, I'm kind of a slow learner.
I know the feeling...seems like every day is a learning experience.
