Benniesimmons
- Mar 3, 2023
Rick can you give me a recommendation on which one? I see so many options.A small set of solar panels with a charge controller and your batteries will be no problem.
Rick
A couple issues when storing, with solar maintainers.Rick can you give me a recommendation on which one? I see so many options.
Why would you suggest hf panels? A PowMr 60 amp MPPT controller from Amazon is under 100 and 250 watt solar panels 50 on the used market!!! If you want a good deal HF is just wasting money.One of the 100 watt Harbor Freight solar panel kits with a charge controller will work - maybe $160.00. This will be plenty to keep your battery charged. Even one of these panels might be enough with good sunlight, certainly two of them.
Rick
Not everyone has the knowledge to know what all the components needed and the right combinations. Kits that have all the pieces in a box(es) makes it possible for many others to try something they wouldn’t have the knowledge or confidence to do without the kit.Why would you suggest hf panels? A PowMr 60 amp MPPT controller from Amazon is under 100 and 250 watt solar panels 50 on the used market!!! If you want a good deal HF is just wasting money.
