MarkMaxPayne
- May 24, 2023
- Beaverton, OR
- New Aire 3543
- 36'
- Spartan
- Fiat 500 Turbo
On my 2023 Newman New Aire my three vent panels keep dropping from the ceiling. It appears that the magnets they compression fit into the wood panel frames with some CA glue keep popping out of the wood. Once enough of them work their way loose from their sockets the entire panel drops.
I've tried prying them off the metal rail they adhere to, pushing them back into the wooden frame where it has been milled to hold them, as well as gluing them back in (thick CA). They still pop out as CA and magnets don't adhere well.
I am thinking of four possible solutions. One is to use strips of magnetic tape with 3M adhesive on the wooden frame (stapled). The second is to bore the magnet holes out deeper so they are flush with the wood and apply a super thin acrylic over them (will the magnets still hold the panel in place if not making physical contact with the metal frame in the ceiling?). Third is to try a coat of epoxy over the magnets and wood (may try this first). Lastly, is to punt and instead attach some velcro, stapling to the wood and some epoxy to attatch compainion side to the metal frame.
Anybody else having this issue? If so, what has worked to solve the problem in your Newmar?
Best,
-Mark
Best,
-Mark
