No power
Farrout54
2006 tiffin phaeton qdh. We have 12 volt but just plugged in and no power to rv
we have checked breakers etc.
thanks
Pat
Do you have a smart surge protector that may be blocking power due to a problem with it? Can you fire up the genny and see if you have power then?
How old are your batteries? Having measured and found "12 volts" is halfway meaningless. The battery must be able to deliver sufficient amperage WITH 12 volts (more precisely, 13.8 volts) and old, dead batteries . . . can't.
Rick
Have you checked your cord or the port where you plug into the RV? Also not knowing your rig do you have a transfer switch and converter inverter? Check the breakers on the inverter. Also check to see if your GFI outlets have tripped
