Question Entry door window removal
lostinfla
Professional nobody
Dutch Star
2026 Willys 2 door XR
So, the window in the entry door has started to fog. I have a new exact replacement window I purchased from Lippert (Duncan) to install, but before I attempt taking the old window out, thought I'd ask if anyone has done this and if there are any tips. I've removed other frameless windows in the coach by removing the inner trim ring, but this sits more flush to the body. Just wanted to know if there's sealant tape or what in there.
I replaced this window in my Phaeton and as I recall, it was simple as removing the metal trim around the window and then pushing a bit here/there to get it out. Different coach, but probably the same procedure.
@lostinfla please post your results - mine isn't doing this yet but the inner seal is pulling out from the corners somI might have to R&R it to fix that. I’m guessing your OE window is from Hehr?
Yes, Hehr. Duncan made it to order to original specs, and (if picked up at their factory), less than half of Newmar's price. I kinda figured it came out like the others after removing some caulking. I'll get the inspiration to do it after a little more time recouping from shoulder surgery. 🙄
