Outside sprayer
Russellvh
Forest River
Wildcat Fifth-wheel
2019 Ford F-250.
IMG_2106.jpegIMG_2108.jpegIMG_2105.jpegI have a sprayer hookup outside. I have never used it until today. I hooked it up and only got a trickle of water. I tried on city water and tried with pump off and pump on. How does it work?
Nope. Didn’t receive any trailers papers. Only paperwork was generic books the water heater, leveler, microwave and furnace.
It may be flow restricted. Put the spray head on the the hose and see if that helps.
Went to e-trailer to see what you were talking about!
Thanks, the hose has a trigger sprayer. Like for garden. We were going to use it to clean out outside chairs.
You may be having to high an expectation. My understanding is it is an outside rinse off shower as In clean off that beach sand before you have to face a broom handle because you tracked it in.
I know that type of restrictor has little use in an rv park, but in the boondocking world it's big.
Where's the valve?
The picture has the instructions
The writing on the inside of the “flap” just refer to draining if freezing weather.
No valve, I’m aware of, just a hookup. Here’s a picture of the full hose.
Have you tried to ask a forest river dealer how much water to expect, and if the quick disconnect on the line is compatible with the male end on the blue hose,I would start with taking off the trigger sprayer ,then plug back in if no pressure I would try to remove the quick disconnect from the line. But is it possible that blue colored hose is for something else.
If someone else has had the trailer, I would not take it for granted that the two parts go together. I hope this helps .
