Resolved Radiator squeal
Staff member
RVF Administrator
Picked up the coach from storage to take it in to get rear shocks replaced. When standing behind rear radiator I hear a squeal that I don't recall hearing before. Hope it's not a bushing bearing or something going south in the fan or something back there. Made it to the destination okay but will have to keep an "ear" on it.
It’s probably a lack of use protest.
protesting hey arnold GIF
Bad bearing=rough sound!
Bushing=squeal,but will quite down.
Belts needing adjustment? Maybe, do they use belts?
Kidding aside Neal. Do you start your coach periodically when in storage. I do. Keeps everything in shape. Some say leave it alone and some say do it. I don’t know if there’s a real definitive answer.
Yes. Monthly.
Belt. It'll be easier to change now than on the roadside
With th age of your coach I would look at belt first unless you’ve changed recently
Yeah, a squeal I would think belt first.
Thanks all. I called the shop this morning and asked them to take a listen when they pull it in to do the shocks.
not to add to your stress, but when my exhaust manifold warped, the sound was a squeal like a belt or a bushing. Very much doubt that's it. It’s a known defect in the 6.7 and I haven’t heard of it happening on an 8.9, but it was an interesting experience.
not to add to your stress, but when my exhaust manifold warped, the sound was a squeal like a belt or a bushing. Just sayin…..
I’ll be very interested to hear about the improvements with the new shocks
I doubt I'll notice. My goal is avoiding destroying the tag axle tires. The ride was already great. I'll certainly post if I notice any change, better or worse.
I’m at 70k miles on mine so I figure its about time. I put Koni FSD shocks on my Bay Star and while there was a minor handling improvement, it made the ride too harsh, so I’m a little reluctant to put them on my Ventana without getting some first hand observations.
I put Koni's on the front right after getting Active Air. Been fine, but no difference noted from the originals. Had the bad wear pattern on tag axle tires and now that I have new tires I'm doing all I can to avoid that on the new ones.
I had them put on the front of my ventana and I thought they made difference. Of course no shock is going to make any ride better on stretches of CA highways.
Well one shock would but I don’t see that happening in the foreseeable future.
Back to the OP:
They tell me belt tensioner and/or belt so they'll replace both for around $2K oh joy. I'll chase down the two parts and take it to them in the morning, one from Cummins one from NAPA. Is what it is, at least no breakdown or tow then repair.
Back to the OP:
have them evaluate the water pump while they are in there. It’s only about a $150 part but the labor would be the same as what you are paying now. Its probably easily a 100k mile pump but if you don’t foresee being this far into it again between now and then, you might want to do it now.
Do you work for Visa?
I would probably need to chase a part again, may just defer this to the annual FL Gaffney visit.
