Resolved Radiator squeal
I had them put on the front of my ventana and I thought they made difference. Of course no shock is going to make any ride better on stretches of CA highways.
Well one shock would but I don’t see that happening in the foreseeable future.
Back to the OP:
They tell me belt tensioner and/or belt so they'll replace both for around $2K oh joy. I'll chase down the two parts and take it to them in the morning, one from Cummins one from NAPA. Is what it is, at least no breakdown or tow then repair.
Back to the OP:
have them evaluate the water pump while they are in there. It’s only about a $150 part but the labor would be the same as what you are paying now. Its probably easily a 100k mile pump but if you don’t foresee being this far into it again between now and then, you might want to do it now.
Do you work for Visa?
I would probably need to chase a part again, may just defer this to the annual FL Gaffney visit.
Calling them now to ask, what the heck...
Anytime I’m paying for the labor anyway I look for other things they can do that will only add the cost of the parts. The crankcase filter is another one - if they have the floor open anyway you might as well have it done early. And we all know you love to spend $$ on the Vantessex anyway…
I'm not sure they would access these parts through the floor or if they access it from below. We'll see what they say, anything to avoid a breakdown. Been there done that once, not fun at all.
The tech said he didn't see any sign of leaks and says they are reliable but it's up to me. When I go to Cummins to pick up the tensioner I'll see what the water pump kit costs, may just get it and put in the spares kit if I don't have them install it. Sure wish I was at Gaffney, labor elsewhere always sucks.
Did they pull your radiator or leave it in and go in by removing air cleaner?
No clue, I'm at home.
Even at Gaffney they may not have it.
Based on discussions here I picked up an “emergency” group of spares while we were there. They had everything except the belt. Don’t think they get many M2 chassis’s there though. Did get me the part number so I can pick up one myself.
When we were pulling out Saturday morning, we pulled next to a Dutch Star hooking up their toad. When I got out to hook ours up he looked over, belt in hand, and said “we didn’t even make it out of the parking lot”. Belt had come off.
4th time they have lost the belt and nobody can seem to figure out why.
Good idea to carry spare parts just in case.
I carry filters and a belt but with a rear rafiator coach changing the belt on the side of the road would be a very unpleasant task. Because of that I had my local Freightliner shop change the belt at around 55k when I was there for something else. it was way early for a belt change but I viewed it as preventative and I feel better about it. Also had them check everything the belt turns while they were in there.
Got the coach back today with new rear shocks (4 x Koni's) and a new belt for the radiator. Squeal is gone. Thanks all for the tips. They wanted to replace the tensioner but could not get it off and were afraid of breaking it which concerned me and made me regret saying anything until next Gaffney visit but all worked out. I'll take the unused tensioner back to the local Cummins location and get my $300 back which is nice. Happy it all worked out.
Can't notice any difference on the rear shocks but never felt an issue before. This is in hopes to protect the tag axle wear but time will tell, 62K miles so probably time for a replacement.
/end
/end
Interesting- thanks for the update
