Aftermarket Shocks For 2022 Newmar Ventana 3407
No Plan
Meandering Around In The Rocky Mountains
Ventana 3407
34' 10"
Cummins 360 HP
2022 Jeep Wrangler Sport Altitude/Air Force One and Blue Ox
The majority of my travels take me on a number of twisty mountain roads. I am hoping to calm the yaw and pitch when going around 20-35 mph corners and switchbacks. I have read that some have installed Koni shocks on their coaches. But after checking into Koni shocks, and I had my dealer check with their parts supplier, there doesn't appear to be a Koni shock available for a 2022 Ventana 3407.
I am looking for information here to confirm this, and if that's the case, is there another shock I should consider to calm the yaw and pitch on my Ventana? Bilstein shocks perhaps?
Thanks in advance...
In my opinion, shocks are not going to fix what you're feeling, this is simply what driving one of these rigs feels like. The only alternate option would be to add HWH Active Air which I have on mine but I believe HWH is no longer installing Active Air. In essence, Active Air would calm the leaning motions from your higher center of gravity by rapidly adding air to the outside air bags countering the leaning forces.
Agree the shocks are only going to have a marginal effect on the roll. Valid also makes an excellent air leveling system. Have it on our 2020 Mountain Aire - to the best of my knowledge on all Newmar MA and up. We spend at least several months a year on mountain roads in the Rockies and I really never feel any significant roll or motion (until I push ‘ol Mae too hard Into a corner going to fast - (Different topic - driver error). Air leveling is not going to be cheap, although it can be added as a subsystem to I think any existing airbag system.
Thanks gents for the replies and insight. I was hoping shocks would help with the stabilizing on the coach in the tight low speed turns. In my performance track cars shocks would keep the car planted in the corners... Evidently not the case in a coach.
My experience with Koni was on a Bay Star and they improved handling a bit but they made it ride so harsh that I was going to put the Bilsteins back on the front if I kept it, and I made that recommendation to the person who bought it. Konis may be different for an XCR chassis but I’m not going to take the chance.
At 60k miles I’m probably ready to refresh the shocks and I’ll likely go with OE (Sachs) shocks if I can find them. That said I too have active air and it really keeps things managable in the curves but does nothing for the very slow speed, parking lot type bouncing back and forth, going over uneven entrances, and speed bumps. I don’t think anything will help that - certainly not different shocks.
Supersteer sells a an improved rear sway bar kit for the XCR, and theoretically this would help, but I have never seen any independent confirmation on that. If you want to give it a try I’d be thrilled to hear about the results.
After a fair bit of modification on a 2018 Canyon Star I was able to get the suspension to be on par or better than any sub 7 figure RV available today, DP or otherwise.
This was verified by an RV experienced friend, who also happens to be a Monaco DP expert/owner/driver 30+ years. He was amazed at how well the RV handled.
It took some doing and $$$, but with the addition of a carefully selected modifications these RVs can be made to handle well. Much of what you are feeling is the vintage truck/bus suspension. Solid Front axle does not help.
Not sure if any of this applies to the Ventana Suspension, but we installed Supersteer heavy front sway bar, SuperSteer Front Radius Rods, Safe-T- Plus , Koni Front Shocks, and a Liquid Spring Rear Suspension. The RV was rock steady and stable. The radius rods improved "turn in" incredibly. No delay in turns especially on local roads. Radius Rods and Sway Bar eliminated any wonder on uneven road surfaces.
We drove the back roads in New England every year and were always comfortable with handling.
The RV was Stable in virtually any crosswind (tested up to 40 mph INT-40 in NM), overtaking vehicles/Trucks passed by unnoticed, easily handled uneven, curvy mountains roads (both East Coast and West), and had a comfortable ride.
Typically drove at 63-65 MPH comfortably on limited access roads.
Hopefully the new 2024 DutchStar will not require this much attention.:cool:
Reading Joe’s post reminded me of these for air bag suspension:
I don’t know how well they work but if there is any improvement in low-speed rocking caused by uneven pavement, speed bumps, pot holes etc, it would be worth it considering the low cost and ease of installation. Something to look into and if you try them I’d like to hear about your results.
One thing you that has been determined conclusively is that you can’t mess with the steering on a comfort drive equipped RV with a safe-t-plus or other steering control adjunct. Confirmed by the designer, Ken Sherwin.
It has been a while-did you install the Koni's?
I did not... As I mentioned previously, my dealer checked and there doesn't appear to be a Koni shock available for my Ventana 3407.
Go to SuperSteer and other vendors and they list two different Koni's
Koni Freightliner XC EVO FSD Front Shock Absorber - 9905 1030 or​
9905 1020​
Check with these guys Search - ShockWarehouse Its very common to have to look beyond a dealer to get answers.
Thanks for the information... I will reach out to my dealer and have the chassis side check on this. I will be back in the area in early August and if they confirm these are available for my Ventana 3407 I will see about having them installed. Thanks again... (y)
Email shockwarehouse.com and provide your VIN and see what they say. They told me exactly what to get for mine, worked great.
I have a version of those on my 2018 Phaeton Powerglide chassis. The porpoise action is gone completely, the rolling over driveway approaches and bumps greatly diminished.
Mark
All that said, I doubt you’d see much difference with new shocks on a 2 year old coach. Mine is 7 years old and 70k miles so I’m now considering new shocks and would expect to see some improvement, not so much in handling, but in response to potholes and other bumps and jolts that take their toll on the house and chassis. I’d really like to find a solution to the very low speed pitch and roll but even Active Air didn't help that.
You’d have to move out of CA. I just ran up the 5 to Portland and Seattle and came back down the 99 from sac to Bakersfield. Abysmally bad. Even in a Prevost.
yeah highest taxes, worst roads, schools, etc. I guess they dont make shock absorbers for that. Couple questions - is there still a lot of construction on 99 and (slightly off topic) have you gotten a smog notice for your coach yet?
There still some construction area between Bakersfield and Modesto meaning barriers and barricade flashers. I went through at night so I didn’t see any paving equipment. Now 5 is a disaster going north between Westley and Santa nella. Traffic was backed up for miles down to one lane in the afternoon while they pave. I haven’t gotten a notice yet.
I ordered the Koni's yesterday
