Soft floor
Russellvh
Forest River
Wildcat Fifth-wheel
2019 Ford F-250.
First trailer since a pop up in 1978. (All tent camping) our 5th wheel is about 2 1/2 years old. I have started feeling some soft areas on the floor. Don’t see anything discoloring and no feeling of moisture or reason for the soft feel. One spot is in kitchen and one upstairs near bathroom.
Is this just normal from movement or should I get inspection? 🧐.
are they near the wall or under a window or vent? soft floor is never good, as @B52Bombardier1 predicted, most likely a leak, I've seen it run down inside the walls under a window, from outside and rot the floor inside, had one in the floor, front closet of a 5'ver and traced it to a seam on the roof cap, caulking was pulled away, leaks are tough to find sometimes
When you're looking for a leak is when you find out water defies gravity, it will run uphill.
The one in the kitchen is about 10 inches from a wall at end of island opposite end from sink and the upstairs is between bathroom and outer wall.
I guess my next step will be to disconnect the under belly and start feeling around. Thanks for the response.
Does Forest River have a 2-year warranty?
This is what house inspectors use.
Boat inspectors use same basic tool for core material,but calibration is different.
Likely either would work by checking in known dry locations for a standard to reference.
Nice, didn't know this tool existed, thanks kevin, off to Amazon, again
Helpful, thanks.
You May be able to rent from a tool center
Soft spots can also be a result of the layers of the floor material breaking down. Most RV floors are a sandwich of up to 5 layers, if you include the undercoat. The layers include floor coverings (tile, vinyl, carpet etc.), luan plywood, sheet foam insulation and another layer of luan plywood. The air bubbles in the expanded foam sheet will degrade. The glue used with the fibre to make the luan will break down. Usually most noticeable in high traffic areas. Check the floor joist spacing if you can. One of the things I quickly learned during my time on RV production lines, RV mfrs don't follow normal construction standards. Get a moisture meter as already linked to be sure.
Edit- came across this article during morning coffee https://www.rvtravel.com/ask-dave-rv-flooring-soft-top-board-replace-1909/
Maybe this should be “soft floor #2”.
If / when I find moisture what’s a best guess cost to redo the whole floor correctly? 37 ft 5th wheel.
Not overly handy. Maybe I should ask cost to have floor redone?
I don't think that is an option! Options exist to strengthen the floor but to do it properly? Ehh!!!
