Question Slide lock not fully retracted?
I don’t have a picture right now while working my other issue (post) but this morning I had an issue bringing in the FWS where the white slide lock at the top caught the edge blocking the retraction at the end. I have noticed they were not completely retracting (down) when the slide is out but to date it hasn’t been an issue. Now it is.
Has anyone replaced or adjusted these? I think based on the fact both front and rear are the same it must be the mechanism at the bottom (plunger) that needs attention.
Any suggestions?
Neal, if you have what looks like paddles at the bottom end of those slide locks, you probably only need to lube the mechanism. I spray WD40 liberally at both ends of the mechanism. Get it down inside. You should be able to manually work the mechanisms from the botttom with your hand.
I agree… I recently lubed all of mine as well. They are hard to press!
Thank you, I did that this morning as well, did see some rust up in there. We'll see how that works out over time assuming no more issues like this morning. As Newmar is taking short notice service visits and I'm in the "zone" of going there I may see if I can get in as I've seen this issue coming for a while now.
I would love to see some pics you guys of what is sticking where, I have some slide lock issues that are still trying to be sorted out, but by your descriptions I may have a different style of lock mechanism. (Or my coffee hasn't kicked in yet, either is possible).
We all use WD-40 for lubrication but it's not a lubricate. I suggest using Liquid Wrench penetrating oil.
BTW, Neal, it would help if you used that motorhome more. Motion is lotion.
I use LPS 2 and 3 - love these lubricants. Didn't know them until my airplane maintenance.
This morning it happened again but I realized I caused the spring to disconnect but they still aren't laying down properly. It seems I need new springs at least but the problem is most likely the bottom compression plunger. I'll see what Joe at Newmar parts says about getting some springs. I'm including a picture, attached, of my kitchen slide to show how it's supposed to lay down with the slide extended.
We'll see after a few cycles if the LPS 2 I flooded it with yesterday starts working its way in.
LPS 2 is great for your steps as well, which reminds me I need to lube them as it's been a while. Any metal to metal moving parts is good to lube with LPS 2.
I emailed Joe at Newmar Parts asking about replacement springs for the slide lock mechanisms on top of the slides as I have one that needs to be replaced. If anyone needs the info here it is:
PN 117048A - $7.43 each
I had to replace one of the slide lock springs. They are small springs for the price. Don't drop it while installing.
So you can skip My post on this if you want, because I avoided many of the issues you guys have! But lubrication IS desirable in most walks of life, so for mecanical issues, I use a penetrating oil that has Teflon in it!!! My last can is blaster,but have also used WD-40 with Teflon.
The advantages are well known:
Dry lubricant will not gunk up with dust!
Unlike silicone the Teflon stays viable for a very long time.
Can be easily found in many stores.
The Major disadvantage is Teflon can contribute to Cancer, so a good mask is in order when spraying it.
Now that the lube has worked in and I'm still having the issue such as leaving the last CG, at least now I can push on the bottom plunger towards the coach and that makes the lock retract (down) as it should be. I may have to disassemble the bottom area to see what's going on and maybe it just needs a cleaning and better lubrication. But at least I learned more how this works and can manage this.
