I disagree. Mine has been in use for years. As I stated before, when a brown out occurs it's too late.Looks like this Autoformer should only be used when you get low voltage errors, not permanent hookup
I've always use the Burner, much more efficient with 2 long haired women on board, long showers....nuff saidIf you want to save the 22A for OASIS turn AC I/II OFF and use Burner. It needs to keep diesel moving so it should be used frequently anyways. But it's the best way to find amps.
