my65coupe
- May 23, 2024
- Chicago il
- Coachman
- Leprechaun 32BH
- Ford
- V10
- Not yet
In the 4 years I've owned my coach, I've never turned off the battery switch, nor the Inverter. Fortunately, never had any issues. 30 amp requires attention to "energy management"! 50 amp provides total electrical operation and demand. On Generator, never any issues. Boondocking requires, "smart energy usage & management"!Thanks. So stupid question when your plugged into 30amp outlet do you leave the battery switch in the on position?
Schwintek slides? Good luck with those if so.Having trouble with my slide outs
Wo t open or close “ initially”. I have not determined what is the cause because after I rotate the power switch or start the Rv and drive forward or reverse it starts working again. Makes no sense to me
Anyone have a comment or suggestion ??
Just curious, did you get this resolved?Having trouble with my slide outs
After 7 years my slideout doesn't work right, kinda moves but all askew. I tried to get inside to fix it, and see it takes specialized knowledge and experience. If you don't have that, there is probably no easy answer, and like me have to bite the bullet and suffer the agony of taking it in to a shop. If you can get a mobile service to come out, they are expensive, and may or may not be able to fix it. It's the joy of owning an rv.Having trouble with my slide outs
Can you send me that list...getting close to retirement and planning some decent trips.Our coach is plugged in all the time we are home. Forgot one time (unfortunately age related) and turned it off, found the batteries dead, recharged them and never forgot again only because I now have a checklist for all thing necessary.
