Joe Dutchstar
- Nov 3, 2019
- Florida
- Dutch Star 4311
- Spartan
- Cummins
- 2018 Ford Flex
That is a good idea. WIthout the use of an MicroAir Easy starter, each unit will take a surge of 20amps when starting. Thats a big hit if all come on at the same time.Thinking about rewiring the middle air conditioner to the Line 2. The load on line 1 is very unbalanced.
The rear a/c just doesn’t work nearly as hard as the front two.
I was wondering how one would run three A/C’s plus other stuff on 50 amps. I guess I don’t need a Prevost.Even with a full solid 50 amp connection running 3 A/C is maximum load in our RV. Any other load like water heater, house battery charger, cooking , laundry requires shutting down one or two A/C units.
We have now scheduled use of appliances outside of peak sunshine hours.
Four A/C’s on a Prevost.I was wondering how one would run three A/C’s plus other stuff on 50 amps. I guess I don’t need a Prevost.![]()
I’ve found that some campgrounds have old breakers that trip before reaching 50A. I’m connected up to RV-C network which spits out the current for each leg every 1/2 second. When I have a pedestal breaker trip I usually look at the graph of the current and see what the draw was when it tripped. If it was less than 50A, I configure the load shedding (Silverleaf) so that it only allows 45A or even 40A. It all depends on what the current draw was when breaker tripped.It should but have had the post breaker trip here in Bowie TX. Not sure if the energy management system was engaged. It is now.
It 101F today….
Mark - thats a smart idea about reconfiguring the load shedding--wish I had thought of it. I am going to adopt your practice from now on.I’ve found that some campgrounds have old breakers that trip before reaching 50A. I’m connected up to RV-C network which spits out the current for each leg every 1/2 second. When I have a pedestal breaker trip I usually look at the graph of the current and see what the draw was when it tripped. If it was less than 50A, I configure the load shedding (Silverleaf) so that it only allows 45A or even 40A. It all depends on what the current draw was when breaker tripped.
And still only 50A service.Four A/C’s on a Prevost.
