bpaikman
- Jun 25, 2020
- Lake Jackson, Texas
- Ventana LE 3436
- 35 feet
- Freightliner
- Cummins 340 hp
- 2013 Subaru Crosstrek - manual, flat tow
at the Newmar rally, we were introduced to the Kleen Tank folks. Went to their workshop, and Bob was sold on the idea.
So, we had them they clean our tanks with some pretty strong spray and a hose system. There is often an accumulation of something called struvite in black tanks (look it up on youtube).
They said that our average for the age of the coach, but the gray tank was unusually clean. They asked do you wipe your dishes off before washing them and we said yes, we do. They said it makes a huge difference, and actually, they’ve cleaned gray tanks that were worse than the black - so bad, their hose would be clogged with debris.
Anyhow, they then instructed us to use a recipe of Calgon Pearls and Pine Sol for tank treatments from now on and they gave us two starter bottles of the solution. Calgon pearls can be difficult fine, but they are available on Amazon with a several days shipment.
They said the idea is not to treat your tanks. Those are holding tanks, not treatment tanks. They encourage the use of lots of water. The idea of the Calgon is to make tank walls as slippery as possible so that everything sluices out. The Pine-Sol is …well… a disinfectant and cleaner. Interesting.
Since then we have had no bad odor whatsoever.
Bob dumped the tanks today (after 5 days), and there’s usually some odor in the coach while he’s dumping, but there was no odor. When I poured the Calgon/Pine-Sol treatment into the tanks it did make the whole coach smell lovely - Bob commented when he came in how nice it smelled.
Also, when he’s dumping, I usually catch a faint unpleasant whiff inside the coach…but not today.
So far, we are impressed. We will be heading to warmer climate in the next few days …traveling north Texas in 100°+ temps - we’ll see - they did say to use twice as much solution in extreme heat.
