Generator Exhaust Smoke
Texas Clodhopper
Garden Ridge, TX
Ventana 4369
Longer daily
Cummins
2025 Jeep Gladiator
I'm dry camping with my genset set on auto start at low (12.2v) voltage. I noticed this morning when it started a pretty good puff of blue smoke. What say yea?
Did it stop smoking quickly?
Mine does the same, except it’s more white than blue IIRC. It’s done it since birth.
I've never noticed it smoking before and it only smoked for a few seconds at startup. It smoked at startup like a flooded gas engine.
Update: When it started this morning it puffed smoke for maybe 5 seconds and the generator was running very rough for a few few seconds, just like a flooded gasoline engine will do. Once it getsd over the rough running, it runs fine.
Yes, diesel.
I’m not sure if those generators have glow plugs, but when I owned a diesel p/u I had a glow plug solenoid go out. Since glow plugs did not activate it would be hard to start, run rough at start and puff smoke until the engine cyl got warm.
It could also be a dirty injector maybe? I use to use injector cleaner additives in my fuel. I don’t know if you can with that DEF stuff anymore?
How cold was the ambient temp?
I have noticed a bit of smoke on startup in 2 conditions:
1) when we didn’t run the gen at least once a month
2) when it is “colder”
The more regularly we run the gen, the easier/faster/cleaner it starts.
Once, when bored, was reading the owners manual - discovered that Onan states the gen should be run at least once a month for a couple hours. Hmmm, wasn’t doing that before, but we now have a reminder on the calendar to run it if needed.
Sounds like your oil is over filled. These GENs do not like excess oil.
The temperature was mid 40's.
The genset has been running very frequently in the last 2 months and the AGS runtime is 2 hours. It normally will have a 40-50% load. While in storage, I have always run it monthly.
Run some injector cleaner in your fuel. Both engines will like it. Methinks you have a slightly leaky injector. Once it starts and pressures up and starts making horsepower the smoke goes away.
