Jim
- Dec 18, 2019
- North Carolina
- Essex 4543
- Spartan
- Cummins / I6 Diesel Pusher 605HP
- 2016 Jeep Rubicon
We have Brake Buddy and have had it for probably 15 years. I have sent it to the manufacturer once to have the compressor rebuilt. It does work well (I test the brake away system periodically) and it's not that difficult to hook up but but to me, it is sloppy. No matter how I adjust the bracket that rests against the seat, it is sloppy. Doing it again, I would rather have a permanently mounted system. I think I paid about $1500. Cdn back then.I haven't used a breakaway system before, but after watching the runaway Jeep in a previous thread, I've decided to get one. So I have no experience in what to look for. Who is using what, how difficult is it to setup initially, and what was the cost?
TIA
www.mgbrakes.com
Me too!I have used the M&G Engineering system since 2008 on 4 different toads. When I bought my GMC Canyon, I had M&G install the brake, brake-away, diode brake lights, and Roadmaster baseplate for less than $2500.
Brake Systems for RV Towing | M&G Brake Systems
M&G Brake Systems is the Brake System for RV Towing that integrates the brakes in your coach and towed vehicle to act as one, providing safe, proportional braking. They are 35% more powerful than Air Force One, and no electricity is required for normal operation. No maintenance is ever required...www.mgbrakes.com
I have to agree - I’ve never liked conventional base plates. The connections just seem so small, even minimal to me. That’s why I built my own mounts and bolted them through the bumper and into the front cross member of the jeep frame. If I were using a typical base plate I would have probably opted for the break away braking system too. They just don’t look stout enough to me. This is also why I used a receiver extension with a 6” rise to keep everything level. I also used them to mount my rock screen to stop the damage to the jeep.Having seen baseplates that failed etc we would not run without a braking system. A lot has to happen to come completely disconnected but it can happen.
That said we like the Demco braking system. We have the Stay and Play Duo in our current toad. Same system as our old one had.
Could have gone with their Air Force One since we have air brakes now but stayed with the old setup. Would have had to install the extra lines and connections for the air hookup. Nothing to hookup this way, just turn them on.
Has worked great over the years in both toads and set so they are more for breakaway now since the coach doesn’t need help stopping the extra weight.
It was interesting meeting a couple in the site next to us from Canada.I have to agree - I’ve never liked conventional base plates. The connections just seem so small, even minimal to me. That’s why I built my own mounts and bolted them through the bumper and into the front cross member of the jeep frame. If I were using a typical base plate I would have probably opted for the break away braking system too. They just don’t look stout enough to me. This is also why I used a receiver extension with a 6” rise to keep everything level.
My recent baseplate failure, as you may recall:
