Eager to learn more about this also. The only thing that I could find is that the controller should be changed/upgraded to their latest model ME-RC-L It will allow a custom charging profile. I've attached a link.Magnum Controller ME-RC-LI have a 2014 Fleetwood Discovery 40E and I was if anyone has upgraded from lead acid batteries to lithium batteries if so did you have to upgrade your inverter as I have the magnum
Adding the Li-BIM was a good note. Thanks.I have the 2812. All I had to do was add a Li-Bim to protect the alternator and I was able to buy a used ARC-50 to replace the Me-RC-50. That will depend on the versions of the inverter and the controller. I also added a battery monitor kit, but I think you can operate without it.
Hi Richard, I upgraded to the ME-RC-L controller thinking it would give me custom control. It didn't. On the current controller push the tech button and turn to versions. My inverter version 3.6 got me nothing.Eager to learn more about this also. The only thing that I could find is that the controller should be changed/upgraded to their latest model ME-RC-L It will allow a custom charging profile. I've attached a link.Magnum Controller ME-RC-L
