DennisT
- Dec 1, 2022
- Superstar 4061
- FCCC
- Cummins 360
- 2022 Jeep Cherokee TrailHawk
- Yes
Know this is an older thread but we just replaced the one I had referenced earlier in the discussion…
Went with a Ninja that does pods, grounds, and has options for cold brew.
Ninja Pods & Grounds Single-Serve... Amazon.com
Has worked quite well and is much smaller that our previous pot.
Since I like ground coffee instead of pods I like the brewing over grounds option.
It has a permanent filter but those are a hassle to clean.
Found these filters that go in the permanent filter and work well with easy cleanup.
MUCXNIIY 1-2 Cup Brown Coffee... Amazon.com
Had either a Breville or Krups grind and brew years ago, worked well but large.
if you go that route a burr grinder is better than the blade type for grinding the beans.
We have this one that is headed to the coach currently. Instant™ Dual Pod Plus Coffee Maker
When we want regular we use the k-cup side. When I want espresso just use the original Nespresso pod side.
Has worked well for us.
