FIUNIE LifePO4 Battery
RVThereYet
Ft Worth
Alliance
Avenue32RLS
Fifth Wheel
2026 F350 HO
Hello to all.
I'm looking at replacing my batteries in my 5er.
I was stuck with Interstate 88AH batteries as that is the only ones that would fit in the storage slot.
I am looking at a LifePO4 12V 200Ah Bluetooth, 2560Wh Lithium Battery 200A BMS 8000+ DEEP CYCLE Marine Battery 10 Year lifetime for boats, RV, Home energy systems.
Has anyone had any experience with this battery?
The price is right on AMAZON at $319 and the reviews from 132 are 4.6.
Can't see spending $500-$600 on a battery when not full timing and even tho plan on doing some boondocking in the future.
I do have 400W of solar and I think that the 5er being a 2023 Has the charger that will handle lithium battery. I will check tomorrow, if I can find it.
The inverter is mounted on the roof of the passthrough.
Clear left, Clear right, the firing line is CLEAR!! Fire at will!!!!
Go for it! What are your concerns?
Not sure i'd say concerns, just probing for information on a product to see if any one else has bought one and get their reactions. At a price $200 lower than the next competitor, makes one wonder if it is just a cheap mock knock off or not.
Just keep in mind LiFePO4 batteries come in various "grades." I finally found an article on this that may help, or not, as you won't know the grade of what you're buying:
But many are really just building their own LiFePO4 battery banks and selling at a steep markup. You could build your own quite frankly. Try checking this forum below and the forum owner runs a very informative YouTube channel as well you could search to see if there is any info on this brand. Let us know what you find.
A lot of these chineese / knock off batteries are just outright dangerous. The protection circuits don't trigger, the welds or solder or connections are barely hanging on.
Is $100 worth your place burning down in the middle of the night? Can't put piece of mind on that for me.
Spend a few more and get a proven quality build from something like temgot, li time, or watt cycle in the bargain side of things. Currently $431 for the 230 li time plus. Amazon.com
Will prouse recommended this one.
breal14,
Your comment is precisely why I posted this question. As the post above you stated, you don;t know what "grade" you are buying. I was/am trying to see if anyone had a pro or con for this battery. I have been around long enough to know that you get what you pay for but I also realize that sometime, if not oftn, makes jack up their prices cause many people thing that more expensive is better.
I agree that $100 bucks is not much but if that LifePO4 that I mentioned is as good or better than the one you purchased wouldn't that just put a burr under your saddle?
Just trying to find the bestest for the leastest!!
Thanks for your comment, I will take it under advisement.
PS. Would not be a bit surprised if the two batteries, that are both in my hold for later at Amazon, are made by the same knock off Chinese POS!
Happy Glamping!!!!
Thanks for the excellent article. IT will come in handly trying to isolate THE battery that I need.
A 200a BMS Daly brand will cost you around 170 us so what will you be paying for?
Check out this company. They have more affordable options not listed. Energy Storage Systems | POWERSYNC Energy Solutions
Will P just posted a vid about DumFume.
Positive results with the $132 100ah model. on par with li time he says.
I wonder if the 200/300ah variants are made the same?
Either way, put a 100-150 amp fuse on these things depending on your load.
I saw that video last night. Looks like a great deal. MANY of the LiFePO4 battery vendors super market them up yet they are the same internally, assuming decent grade of battery cells. Check the warranty, if good, I'd jump on a deal like that.
